How would I represent a string of lights all plugged into one dimmer? Is there a fixture to use for this? What patch? What A3D image?
There is no specific fixture that would display like this. You would need to create a part for each light source in patch and move it to the appropriate xyz-position. Since these additional parts only exist to help Augment3d, these additional parts don't need any DMX address.
Maybe this support article might help you: https://support.etcconnect.com/ETC/Consoles/Augment3d/How_Do_You_Duplicate_a_Fixture_in_Augment3d
Do you have a suggested fixture you would use for a single light that displays appropriately in A3D?
Probably the closest you can find is the Astera Nyx Bulb.
This worked for me--thanks
