Converting preset pan/tilt values to XYZ using known Z-focuses?
I have a showfile with about a hundred mover presets targeting actors, with focus values recorded as pan/tilt. I am now taking the show on tour and I want to convert these preset focuses to XYZ. However, EOS has somewhat arbitrarily assigned XYZ values along the path of the pan/tilt values, so sometimes the z-value is at 1.8m when it should be at 0.2m, or vice versa.
I know, for each preset, whether the target performer is lying on the floor, standing on the stage or standing on one of several raised platforms. I want to be able to 'lock' the pan and tilt values, set a Z-focus, and have EOS calculate the corresponding X- and Y-focuses. Is this possible to do?
