eos 3.2.11b27 bug with parts in augmented
Hello, i experimented same bug at least since 2 EOS versions: i get some channels with 2 parts (type classic profiles, par cp62 or else). i want to get those 2 parts in augmented. I put them in place, give them parents. this works. then, quiclkly, in many occasions and randomly, (at least i did'nt get the pattern), they loose parents and positions. give it again, they loose again. Sometimes one looses when another one is assigned. Sometimes loose during a quick save. Sometimes loose when reopening file. Sometimes loose 5 of them, sometimes one. I first thought it was with parts2 without a dimmer assigned, but this happened too with a dimmer assigned. Always happening with part2. Should i renounce to get those parts2 in augmented? I did hope i could make my memory renders with aug, this is a problem. Any explanation, or even better any solution to fix it?
  • (plus, randomly in aug, channels are called part 1 part2, most of the time they aren't.)
  • just a question: i know we are a lot on many etc forums, but is there still an etc personn reading us? my 3 last posts did never get an answer or even a reaction.i feel i post for nothing. Anyway, found out where the bug comes from: 2 channel parts nedted to 2 different objects make augmented unstable. i renouced to my organisation, nested them to the same objet, trouble over. So, 2 problems there:
    -channel parts in different objects make augmented unstable
    -when nested to different objects, channel parts are sometimes named part 1 and part 2, but most of the time aren't.
