Ver3.2.12 build 1
Lib vers 3.2.10.23
Halcyon Titanium ultra bright standard pan 540.
Hi, Can you please take a look at this.
I have the 5 facet prism in and in spin mode programmed in a cue, if you manually put the prism to "Open" then sneak it says in "Open" and will not visualize the prism until you manually add it back. Also, With the prism in, it will inconsistently play back without the prism visualized..
David
