Augment3d Import Dialog Doesn't Appear In Windowed Mode
Hi!
I'm not sure where the right place to post this is, but I figured it was worth documenting somewhere as I burned a couple of hours tracking this down!
I'm using ETCnomad on a Mac, and attempting to import models to Augment3d (exported from Blender, in various formats, if that matters any). In the log window I can see the import request making it through, but the model would never appear. I finally found that because I'm running Augment3d in windowed mode, it doesn't seem to render the import dialog. Shutting down EOS and moving back to the default fullscreen mode shows the import dialog successfully.
Pretty easy workaround but I wanted to share that in case anyone else runs into it!
