Apologies for posting some of this for a second time, but there are a few things I would love to see in the eos OSC implementation..
1/ add the parameter group to "/eos/out/active/wheel/1   pan [10]"
so maybe change the return to pan [10] focus or add to the sending - although this could be a breaking change?
2/ Allow the querying of a channel or parameter current value
maybe /eos/get/channel/1 and /eos/get/channel/1/intensity
I am also not clear how the parameter queries work, as some parameter names have spaces (which can't be used in OSC arguments)
3/ Allow request of all active channels (as per active channel display)
maybe /eos/get/activeChannels (which could return an array of CHAN, INT)
4/ allow subscribe to changes in active channels
so once you have queried the above as per 3, you can then subscribe to recieve changes to those levels
5/ Allow a method of understanding the current mode of a parameter (ie is a gobo wheel in index or spin mode)
6/ Allow a method of receiving the names of the step (rather than just the basic value)
7/ A neat way of doing next/last which both only cycles through channels in the current flexi set, but also transmits all wheels each time this is called.. /eos/key/next is a bit intermittent as to how it behaves
Think that's it for now - if some of this is already possible then do tell!
Many thanks
