2.7 patch OSC API
Hello
Are there any plans to get the OSC API up to speed with muti-cell support, currently the cells are sent using their internal addresses (>510000 - it appears that each cell has a 100000 channel block to identify it but there's not capacity to work out how this block of hidden channels is linked to the master channel.
A simple fix may be to add the master channel number as a note, along maybe with it's index within that channel.
While I am on the subject, has there been any joy fixing the bug which means you can't pull changes observed via /notify/patch - as the index sent doesn't appear to be very useful!
Richard
