Using OSC to control a Timecore timecode generator with EOS software.
I'm trying to control a Visual Productions Timecore through OSC commands from my Nomad (2.9.1) and programming wing.  All my devices are run through a network switch. I have successfully accomplished this from QLab. I also have the Timecore connected to the programming wing through the midi ports. I have MTC running into EOS, so those settings are correct. I’m pretty sure the OSC settings are correct in the EOS setup. I’ve attempted to execute a string from a cue, with no luck
What I would like to do with in EOS, is send the commands to start, stop and setup a new time stamp. As I said, I can do all this from QLab.
I’m scratching my head as to what I’m doing wrong in EOS.
Thank you
