ETC EOS Nomad v2.9x. Need to send MSC to SFX6 for sound cues. Does anyone know how to translate the string for SFX? And do I need to send a specific command or once USB Midi is enabled it will just automatically send?
the whole idea of MSC is that you don't do anything to the strings. a console sending MSC uses the same format as the receiver.
in setup>system>showControl>midi> MSC Transmit you will enable MSC. now as soon as you fire a cue MSC will tell the receiver(s) that that specific cue has been fired.
an yes, if you're using a usb-midi adapter you will have to enable USB Midi in setup.
Got that part thanks. I've confirmed that the system running SFX is receiving the Midi Input string via MidiOx. However, SFX does not react to the input.
using SFX Deluxe? looking on the website it seems that Standard license is not enough
Yes, we are using SFX Deluxe I believe the version is 6.3 or 6.4.
in Ion open the diagnostic tab (File>Setup>Diagnostic) when you press Go for a cue, do you see a line like this?
Yes I have the diag tab open. I see the Go Cue and on the receiving side with MidiOx I can see the input string from Midi. I do not think this is an ETC setup problem. I am fairly certain that it's something I need to do with SFX MIDI Patch settings. Just cannot seem to get any details on config issues
