4 Port Male Output Gateway Use ?
Hello,
I found a 4 port gateway at my venue but, the 4 dmx ports are male. I thought that maybe i can connect the RJ45 cable at the front of the gateway and then output different universes. I can't find a practical use for the setup for the gateway connectors.
  • There are different Net3 Gateways, the classic one have changeable I/O modules, maybe your local dealer have some on stock.
    But you can also use a gender changer for outputting DMX data.
    For  configuration you can use the concert software https://www.etcconnect.com/Products/Networking/Software/Concert.aspx
    With the software you can change if the ports works as DMX Output or Input.
