OSC control /eos/fader/ with ticks up/down, rather than a float value?
Is there a way, that I haven't been able to find, to control a fader via OSC with ticks up/down, rather than a 0.0-1.0 float value? Similar to how wheels and encoders can be controlled?
The thought behind this is to have a joystick control the faders level up or down without the need for the OSC sender to know the faders current position.
The assumption here is that there is a cuelist on the fader and the fader is behaving like a master (default settings, proportional master).
I haven't been able to even find a simple workaround for this, like a command line command, macro or MS command..
PS. I haven't understood how the /eos/fader/ commands: min, level, +%, -% are supposed to work. These feel like channel control functions, but I don't get what they have to do with faders.
When controlling a fader that is a sub, commands I found to work are: out, home, full, max.
Oskar
