Bug: ETC_EosFamily_v3.0.0.389 for Element 2
When you select a device, there is no information about control in the dynamic devices window. In version 2.7, everything works.
can you take a picture of your About display? with an *empty* command line press the About key, it should show varios information about your console.
I have now rolled back to 2.7
ah, the screenshot about 3.0 could have helped.
did you know that you can switch software versions 3.0 and 2.9.1 back and forth, just with a click, no need to uninstall and re-install? this doesn't work with 2.7.4, but with 2.9.1. so you could try with 3.0 and if you run into a problem you click a button and reboot into 2.9.1. and if you then have a moment to try again, you click a button and reboot into 3.0 again.
I know that. I was going to do. Now there is a performance. I'll take a screenshot later.
You do not have a valid Fixture Library installed.
https://www.etcconnect.com/Support/Consoles/Eos-Family/Eos-Ti/Software.aspx
Build 117 (the latest) for 3.0.0 here
Thanks! Installing the 3.0 library helped!
