Show Control sACN Event / level by adress Action not working for 16Bit Parameters.
If i try to control a 16 Bit Parameter, for example a Pan or Tilt Parameter of a patched Channel, the incoming sACN Adress which should be routed to Coarse is controlling the Fine Parameter. The same Problem with 16 Bit Dimmer Parameter.
Is there any workaround or maybe there's something i missed, like a Softkey? Thanks
