Hi All,
Sorry new to OSC
can you learn record on OSC like you can via midi timecode? if so how do you set all this up and get it to learn on a go
Using Qlab 4 is it my understanding you start timecode as normal and fires the cues via timecode
Hi All,
Sorry new to OSC
OSC is a great replacement for most MIDI flavors. except for timecode... because oyu can't use OSC as timecode, als OSC commands have a specific meaning. you can't learn anything on the Eos side because the OSC input already knows what to do.
In summary you would do a command string in Qlab and this is the way to do it?
For sending from QLab to EOS simply send a network cue like "/eos/cue/3/fire"
See also https://support.etcconnect.com/ETC/Consoles/Eos_Family/Software_and_Programming/Triggering_Eos_from_QLab_using_OSC
