I have a light that is "popping on", as in acting like it has a relay module in it. It doesn't. And when I run it by just address it works just fine. It is a standard Source4 750w light. I am running a ETC Ion. I checked if it has a curve patched in and it does not. Don't know if it is related but it does have a scroller on it patched to the same channel, different address in a second universe. There are multiple of these lights with these scrollers and this is the only one doing it. It appears to be the same profile in the patch as the others. At least as far as I can tell. Let me know if there is anything else that could cause this that I may have missed. Thank you.
