I'd really like to make a button on a magic sheet that just sends the /panic command over OSC but I don't know if there's a way to send OSC strings without firing a cue in Eos.
You can do it in magic sheet creating a button and add /panic in the command field.
And sending OSC through a macro is possible as well with the macro function Send_String.
