I can successfully patch everything and add locations and orientations and whatnot. It's just that sometimes the "Type" part works and other times it doesn't. In the diagnostics tab it appears as though it's coming in perfectly fine, and it gives a diamond in the command line after the command as if it likes it, but it doesn't actually set the type. I'd think that if there was some kind of syntax error, it would give a syntax error or wouldn't print to command line at all. Or at least there would be an error in diagnostics. But it just doesn't work. This exact syntax was working fine a couple months ago when I first got it working. Occasionally I would have a packet drop and 1 out of 100 fixtures would miss this or that, but now everything but "Type" works every time I try.
Address: /eos/newcmd
Argument: Chan 67 Type Ayrton Zonda_9FX_Basic Enter
