Hi I'm having some issue with External Timecode
My setup chain
1) Loop Midi
2) Reaper Software
3) ETC Nomad fully unlocked dongle
A) New Showfile > check the Source on LoopMidi
B Enable Midi RX TX > setting Show Control
C )Show Control change from SMPTE to Midi check the ID source matches Loop Midi
D) External (ON) top left of my showfile / source turns green
E) learning enable I see appears where External Timecode clock is
F) I have pre recorded 10 cues 1thur10 @full
G) Master fader Fader config set to Cuelist1
H) Running Audio from Reaper Software
I) The world clock is showing 0:0:011 and running perfectly
However during all this when learning timecode
And bumping go to capture Events
The cue list is bugs or there is latency issues and not recording or it glitches out just keep jumping cue 3 to 6 and back while external is enabled and loopmidi are active
When I pause LoopMidi the issue stops
When I go back to playback with internal timecode
to check the Timecode stamps they are not the correct timestamps cause my cuelist keeps bugging out
I also tried RTP Midi running this instead of loop midi but same issue arrive
Does the response MIDI gateway gadget midagate this and make my life easier
Happy to send loads of photos of the process
