Sending OSC From A Macro
Hi, Ive recently been programming my streamdeck to help out a school controlling there ETC nomad using Bitfocus Companion. When using a MS i can set the button target to command and input this command "/location/9/0/4/press" which presses a button within bitfocus this works fine when clicked. However i cant figure out a way to run this same command (/location/9/0/4/press) directly from a Macro. As i want to be able to run the macro, and for it to send the command so bitfocus recives it as OSC the same as it dose from the MS button.
Any suggestions would be much appreciated ?
