Send OSC commands from Luminosus to ETC Eos Family
Translator
Hello dear community,
My problem is that I bought a midi pad to better control the lights at school. Since I had problems connecting the midipad to etc. Eos, I did it using the second program Luminosus. Now the problem is I want to control the x-y axis of the moving heads via my faders on my touchpad. But if I now want to send osc commands as a message to Etc Eos, the ETC eos does not recognize it, even though both are connected via Custom Osc and via Lightning Console. The OSC monitor also shows what is being sent, but Eos doesn't recognize it and doesn't do anything. Could you help me to solve this problem. Custom OSC also says that they are connected to Luminosus, so I don't know what to do anymore.
  • so what is working what isnt?
    is the touchpad using the eos rfr app or one that uses osc as well?
    what do you mean by Custom Osc? what is this OSC monitor? do you mean built in tab 99 or other software?
    can you provide screenshots of your config and logs?
