Hello
I am currently working on a show file to allow touring companies to tie into our rig using sACN. Currently the rig spans 5 universes, which isn’t ideal when they only have 1 or 2 universes available on their desk.
The set up will allow them to plug into a Net3 gateway set as an input to universe 101, and then have a showfile patch each channel in that universe to control certain fixtures.
I have no problem in configuring all this, e.g 512 events, Event 1 takes sACN 101/1 and controls 1/1, Event 2 takes 101/2 and controls 1/2 etc however it’s very time consuming doing this 512 (or 1024+) times.
Does anyone know a quick way I can select event 1 thru 512 and quickly assign sACN and actions on a 1 to 1 channel basis in a few clicks. I’ve managed to create a basic macro which reduces the amount of clicks but I still have to do this process for each event. I’ve tried the “obvious” syntax guesses (e.g Event 1 thru 512 sACN 100/1 thru 100/512 enter) but this just assigns 100/1 thru 100/512 to every event.
Apologies if this makes little sense, but hopefully if you have done something similar yourself it may make some sense.
Many thanks
