OSC Command to qLab over 2nd Network
Ion XE v3.2. Network #1 sending sACN over 10.101.0.XX to control dimmers, nodes etc..., Network #2 sending OSC and UDP over 10.0.1.XX to qLab (same network, same subnet). Both are configured correctly. Sending /cue/1%/start. Fires the cues as expected with no problems. I created some macros for safety (such as double-tap), so Macro 10 = (Send_String /panic enter). There is also a /pause and a /resume
None of the macros work. Any idea why? (those are the appropriate OSC messages for qLab)
  • Generally if cue strigs are being correctly received by QLab we can assume the console is correctly configured.  There is not a setting that would disable Send_String from a macro while still allowing the OSC Cue Send String to output.
    Do you see OSC messages being sent in EOS Tab 99?
    Do you see the OSC messages in the QLab log window?
