Hello! I have an OSC setup where Eos is being triggered by QLab. Everything will be working fine, and then I will toggle OSC RX off, if for example, we are working out of order from sound. When we are ready to sync back up, I’ll toggle OSC RX on. When I toggle it back on the link will not work, and if I turn on incoming OSC logging in diagnostics, Eos does not appear to receive the message. The QLab computer’s settings are unchanged, and that computer is still able to successfully ping the Eos console. If I exit out to the shell and relaunch Eos, OSC will work as intended, despite no settings being changed.
On other consoles in the past I’ve been able to toggle OSC as expected with no issues. This is my first time using OSC on this device and on this network, and I don’t know if this is an Eos setting or a network configuration problem. Any help is appreciated!
