Is there a way to create a Macro to either toggle OSC RX on/off or to just set it to on/off?
I looked through the whole list of commands in the Macro editor and couldn't find anything. (Yeah, I don't have any stress during that play)
First step would be to learn the macro while you go to setup and toggle the setting. Second step is in the macro editor cleaning up the macro.
This will get you a toggle macro. If you want the macro to be deterministic, i.e. always disables instead of toggling, you can add Disable after OSC_RX in the macro editor.
