I might be missing something obvious because almost everything else in Eos has fairly comprehensive OSC access, but it doesn't seem possible to retrieve or manage Show Control Event Lists via OSC?
It's possible to set timecode for an individual cue with /eos/user/0/newcmd "Cue 1/10 Timecode 01000003 Enter" etc
But there's no way to easily configure the same cue from two timecode timestamps (which you can do editing in the Event List) or to configure timecode to trigger a sub at a specific timestamp etc that I can see.
Theoretically you can manipulate the Event list as you can in Blind, but without a means to retrieve either the Event list or the current timecode associated with any list item there is no way to determine what event number corresponds to which position (as the event list position changes if you change the timecode)
Is this an omission in OSC or am I just missing something? It feels like there should be an /eos/get command corresponding to events?
