The ION Console (1.9.11) Live Window (Active Channels) can see some Channels (Type: Cyclo4), (201 > 208) without running the Cue or Subs. Those Channels Intensity color is Green and the underline also. Then Run a Cue recorded those Channels and appear the Intensity Color is Purple. Then Off the Cue, put the Command [GotoQ] [0] [Enter]. All Channels are out of the window except the channels (201 > 208). Sometime those channels vanished from the command of [GotoQ] [OUT] [Enter].
Restarting the ION after the Live window can see the channels (201 > 208). Then On a Cue added those channels, other channels are working normally and (201 > 208) Intensity will be Zero. Again Off and On the Cue, those channels intensities are same as recorded and are working. Some Cue running time those channels Intensity color is Cyan and sometime White. What is this problem and how can be vanish those channels from the Live Window? Why those channels appear all the time? Every time after On the Console those channels appear without any commands.
The Intensity or Color changes after, try to [Update] and can't see the information of those channels (201 > 208). But after Hit the Enter the update will be completed. Other any channel Intensity or color changes after press the [Update] can see the information of that particular channel. I think someone change something and please describe the details. I am expecting your valuable reply.
Thank you,
Ajaya
