Necessary information:
EOS control console
City Theatrical AutoYoke Ellipsoidal with Wybron Coloram II
Question:
Usually with Coloram IIs you set the fan control channel at the PSU. On an AutoYoke, the fixture acts as the PSU for the scroller and therefore you don't need the Wybron PSU. However, fan control is then slightly more hidden. According to the manual, it is part of the fixture control channel, which the console puts under Lamp Controls. How does the console treat these values? Are the values set for the 3 seconds that is in the Steps column of the fixture's personality? And then set to 0 again after? If so, how can I use the fan control? How can I write it into cues? Can I add to the personality a parameter to put it on the Scroller Fan encoder?
Thank you,
-Tim
