Eos Fun Facts
The intent behind this post is to bring to light little known features of Eos and Ion.  The kind of stuff that you wouldn't necessary discover on your own.... that you'd have to read the manual to find (yea, yea) or that someone would have to tell you about.
Maybe you know some you'd like pass along!!
For example, did you know.....
That you can lock out the face panel on the desk by holding down [Clear] & [Escape] .... and unlock it the same way?
Anne
[edited by: Anne Valentino at 10:42 PM (GMT -6) on Fri, Dec 07 2007] [edited by: Anne Valentino at 10:42 PM (GMT -6) on Fri, Dec 07 2007] [edited by: Anne Valentino at 4:06 AM (GMT -6) on Thu, Dec 06 2007] [edited by: Anne Valentino at 4:04 AM (GMT -6) on Thu, Dec 06 2007]
  • Alex,
         I agree, the [recall from] is awesome!
        We usually don't use Automark as It is really easy to use the boards referenced marks feature instead, while leaving you more options.
        Macros can make things much easier.  Lately I made a bunch of Macros that will label cues with common terms like BO, Preset, FOH up etc.  With all of the option I think the Macro and Query function could have a huge impact on speed and accuracy.
    Mark Rhoads
    Lightboard Operator
    IATSE Local 51
    Houston TX
  • Mark-
    I was using the referenced marks for awhile, but here's why I stopped. And tell me if I am wrong. I was breaking marks when we needed to move the intensity fade up ahead in a cue list. So if cue 2 is my show preset, and fixture 381 is Marking out of Cue 5, my first look. But then we decide not to bring up 381 until Cue 12, I will break my mark by simply moving the intensity move. Also, say I have a cue where a gobo rotation is going to start. I want to move my Moving Light into its focus, beam, and color in cue 15, but don't want the gobo rotation to start until cue 29, right before it comes up in cue 30. In this situation, referenced marking seems unnecessarily difficult.
    The macro I am thinking of would be something like: Macro x: {381 thru 387 + 391 thru 408 AllNPs Recall From Cue} where 381 thru 385 would be AS VL1000s 386+387 are T VL1000s and 391 thru 406 are Nexera Profiles and 407+408 are Extreme Green Seachangers (I just love calling them Extreme Green). For any show, it would basically be a list of fixtures with Non-intensity Parameters. Anyways, in this set up I could make my look live, update, hit blind Cue n (wherever I want them to mark), then Macro x type my cue number, hit enter. I've basically been doing this without the macro, and it seems to be working. The only issue seems to be Blocks in between, but that is quick and easy enough to set up. Also if you use point cues that follow after your hard blocks to mark, it seems to keep things very clean.
    Thoughts? Also, nice to see another Houston Board Op on the forums! I just joined the other day but this seems like a great source of cool info...
    Best.
    Alex
    Lightboard Operator
    Alley Theatre
    Houston TX
  • ETCdsmith said:
    This one is obvious but, Double hitting any record target, (Cue, Focus Palette, Color Palette, Beam Palette, etc.) will take you to the list that corresponds with those targets.
    In those views you can lock palettes from being mistakenly updated!
    JoeMac
    More Than Light LLC
  • Alex,
    If you're interested, you can also enter color information in Patch, and then use Query to select units in a specific color.
    When the import from Lightwright functions are a little more robust, you'll also be able to import color information directly from your LW file.  You can import this information now, but it will overwrite any patch information you have stored, so be careful until that is corrected.
    ~P
  • Alex,
    I just wanted to mention that what you want is still possible using referenced marks.
    For adding in a channel earlier in the cues, in live, it's quite easy.  Just bring up the intensity, and because the channel is marking, its NPs have data, which now become hard.  Simply remark (the earliest M softkey might be a help), update, and at enter the channel where it used to come up.  In blind, recall the channel from where it used to come up.  Remark, and at enter the old spot.
    Re-reading your post, you're looking at having a channel come up later in the cue list.  You would handle this much in the same way you would deal with intensity coming up later (and would on the O2 as well).  Go to cue 12, and ch 381 [Block].  This will set both intensity and NPs to hard data.  In cue 5, at enter 381.  Now  that 381 is coming up from 0 in cue 12, it will except a Mark 2.  Probably about as much work, but you preserve referenced marks.
    For your rotator example, you can mark discrete attributes.  So 381 mark 15 enter, rotate mark last enter.
    Here's what really sold me on referenced marks.  You can think of the mark attribute as something attached to the light in the cue it comes up, as well as any other parameters, so you're giving it information about how you want the light in the moment -- ie. "I want the light in blue and I want it to mark from the top of the show."  So the mark isn't part of the marking cue, it's part of the first use cue, even though the action happens in an earlier cue.  Does that make sense (or help :-) ).
    What that means, is that I'm free to think about a channel in the moment.  If I'm adding a channel, I can set it how I want, let it know I'd rather see it fade up all good to go, and that's it.  No blind maintenance, I can just move forwards.  If I make a change, say adjusting a special on an actor, I can just do it and update without worrying about going back and fixing the mark, which helps me stay in the moment of reacting to the show.
    In addition: As you say, referenced marks ignore blocks and warn when lights are active, again facilitating programming in the moment.  I find seeing the cue indication of a marking light really useful to let me know if I'm about to use a light.  A marking light doesn't track (because the light's information is actually stored in the first use cue), so if I add a light with a new set of parameters earlier in the cue sequence, I don't need to worry about it obliterating any parameter data down the line.
    Just my 0.02.  Hope it's useful.
    -Josh
  • Josh-
    Thanks for your thoughtful response...
    Maybe I'm missing something here, but to me it seems like it would be just as easy to use manual marking with the Eos.
    Here's what I am thinking of doing for my next show:
    I just learned about using Intensity blocks, so I'm thinking most of what are full blocks now, I would make only intensity blocks. Then I wouldn't have to worry about making sure NIP's track through my blocks and would just have to worry about the marking cue and the live cue. In this example, if we know where the light is coming up and we are in that cue and we made a change to the focus of the instrument or something, couldn't I just just use a keystroke like Chan 381 {all NiPs}{update} cue 5, then go to cue 12 again, and have my mark fixed without leaving live? Then if I wanted the light to come up in cue 10, it's already in it's preset and I just need to give it a level. Or if I wanted to mark different parameters later, I could do that as well.
    This seems quicker to me than having to worry about @ {entering} anything or using make absolute. And if I have a macro to label cues marking cues, and a decent assistant. I shouldn't ever make mistakes about when a light is being used.
    Just a thought. Anyone else have a system they're using? Also am I just a jaded old Obsession user? : )
    Alex
    Light Board Operator
    Alley Theatre
    Houston TX
  • I have done both manual marking and reference marking. I tend to like manual marking because it is easier to use units if I need to in their mark period. When manually making mark cues I use an intensity palate with the label "M" so that I can tell at a glance units that are marked for use and units that are not.
  • Hi all...not intending to drag attention away from the Mark-discussion...but another useful function that I have just learned very recently:
    Double hitting [ / ] brings up "DMX" in the commandline so you can enter DMX values from 0 to 255 for any parameter...
    E.g. Channel [Number] [Tilt] [DMX] [Value] [Enter]
    I think this can be useful sometimes..
    Cheers from Berlin,
    Matze
  • Oh and one more thing I didn't know for a while:
    Holding down [ Blind ] & [ any Record Target ] works as a shortcut to get the Blind-(content-) view of anything..So you don't have to double hit the record target and then {Edit} or go via [ Blind ] and then [ any Record Target ] ... saves time and as we all know there is no time when programming ;)
    Cheers from Berlin,
    Matze
  • wow! thanks matze, two cool new things i learnt today!
    grüsse und danke aus der schweiz
    Ueli
  • a macro that one of our guys wrote that is simply awesome - select manual, record only-
    speeds the programing  up
  • Lane, explanation please?  Record only just just manual values.  What is this doing??
    a
  • Anne, first it selects manual changes, then it records only; it just encorperates the two buttons into one.
  • [Record Only]  by definition, records only manual changes, so hitting select manual first is completely redundant. If you hit [Select Manual] [Record Only] [Enter] or just [Record Only] [Enter] the result is *exactly* the same.
    -M
  • Just figured this out today and thought it was awesome.
    Say you're doing a show with 3 locations and you keep going back and forth. And the designer has scene specific presets that mark at the beginning of each scene.
    Example:
    So cues 1-10 are preshow. 1 Marks for scene 1 in an office. Cues 11-67 are in the first scene in an office.
    Cue 70 is the blackout. Cues 70-125 then take place in a bedroom.
    Cue 125 is a blackout.
    Then cues 130- 175 are back in the office.
    The designer wants to record Q 11 to Q 130. When you do it, you have all sort of non-intensity moves in Q 130. If you create a part Q in your transition Q 125, we'll say part 7. You can then say Blind Q 125 Part 7 Channel 1 thru 400 (400 is arbitrary, whatever your last channel is) All NPs Recall from Q130. And you've marked everything you need to get back into the office with no live moves...
    I was doing Macros etc. to select all my channels with non-intensity parameters for awhile. I feel like I should've realized I could select all channels non-intensity parameters to make big moves like this. It is great. Another reason to love the All NPs key as well as {Recall From} : )
