What is the maximum number of channels dmx that an ion can output ? I have a movie upcoming that will require 3396 channels . Most fixtures static multi parameter with a a few hundred dimmer channels
Console channels is 10,000
DMX addresses is in multiples of universes, starting at 1024 and going to 3072, with a note that those 3072 addresses can be sent over however many universes the network can handle.
So if you are needing 3396 addresses, you need the next desk up, the Gio.
SB
