Opening/closing ML Control Module
Is there a way to have the Ml control module open in the lower left corner under the channel display but minimized so I can view all my channels and have the ML controls only pop up when I select my ML channels?
I made a 2 snapshots  one that has the ML controls open and one that has it closed, but when I select my channel then hit the snapshot for the Ml controls, it deselects the channels i had selected.
any ideas?
[edited by: Msbrocchi at 12:57 PM (GMT -6) on Sat, Aug 18 2012]
  • I would suggest writing a macro to fire each snapshot. You can set the macros to fire in the background and not interfere with your command line. Other than that the Eos does not differentiate between a channel with one attribute and one that has 45 attributes so there is no automated way to have the ML control pop up when you select a channel that has more than one attribute. At least not any way that I have figured out. hope this helps some.
