Hi.
Got a show with some discrete channel intensity timings, which we need to print to a PDF. Is there a way to print discrete times in addition to (or instead of) intensities?
Thanks.
[edited by: gareth71 at 6:38 AM (GMT -6) on Thu, Sep 13 2012]
Hi.
Thanks.
Hi Gareth
I don't think there is a way to print off discrete timing to PDF. If you need to take this information off the console pressing Time + Flexi will but you in Channels with timing flexi view which will make life a little easier. I you to use the navigation Time key on Eos.
Hope this helps a little.
Nick
Hey Gareth,
When you click on print make sure that the Summary View option is deselected and it will print the discrete times with the channel level information. You may also need to change the paper size of the print out in setup. There is not to my knowledge a way to just print discrete times with no other information. Let us know if you are still having problems.
Thanks - will try that when back in the office next week.
