Couldn't fin anything in the manual or on the net...
Is it possible to receive dmx/artnet and store the values in the desk to copy a show?
Or how does the ASCII in/output work for grandMA to ETC Ion...?
Martin
Martin
Hi Martin,
The Eos Family don't support DMX or Art-Net in, there are generally more 'modern' ways of supporting those needs in most cases.
You can import and export ASCII showfiles from directly with the Eos app through the browser. GrandMA also supports importing and exporting of ASCII files. There may be some features that don't cross over exactly right between the desks, but you will certainly get all of the standard cues and channel levels etc.
Cheers
Dan
dsmurfin said:... GrandMA also supports importing and exporting of ASCII files. ...
Unfortunately GrandMA 2 supports only import but no export anymore.
Thank you for your help!
M.
mhlighting said:Unfortunately GrandMA 2 supports only import but no export anymore
Well that's one more reason to choose Eos over GrandMA!! :-)
No worries, glad to help.
hi all is there a news at this topic. ı want to receive dmx values by Artnet (from Qlab) at nomad. is there way to this.
thanks in advance
This has not changed. sACN is the only way to get "DMX" (original or in an Ethernet protocol) into Eos.
Does it need to be artnet? QLab could send so much more like timecode, osc or midi.
Since people are commenting on this old post, I thought I would chime in that ETC can now convert MA2 and MA3 Showfiles to Eos format. Just send your showfile to ETC Technical Support.
I think so, because of what i wanna do is; transfer light cues to eos quickly, need to recieve dmx values, qlab export nothing about this. Is there another way to this ?
