A request for the direct selects to make busking with movers less cumbersome. Currently we have a few macros with different sneak times which works fine for single direct selects but when you are looking to stack some different parameters this does not work. Some ideas...
- a sub that could be programmed to change the execution time of direct selects.
-add a parameter for direct selects timing and a way to program a background macro that would allow you to change the time
-allow a way to program a background macro to change the manual timing values for focus, color etc..(currently you cannot)
-put the provision (maybe shift) to put more than one direct select into the command line so you can use the sneak function for multiple parameters
Or if anyone has found a better workaround please let me know.
Cheers, Andrew
