Griven PE 575 and 1200
Hi
i have some problems , how to patch griven acrobat pe 575,1200 in etc ion.
help me plz.
and there is one other thing , my sensor dimmer unstable after starting it , the light goes up and down for about 15 min.
Regards
[edited by: Aiman at 7:20 AM (GMT -6) on Wed, Oct 17 2012]
  • To patch a device in Ion, go to [Displays], then {Patch}. Select a channel number, then use the type button onscreen to give it a type from a list of manufacturers.
    Regarding the problems you are having with the dimmer, I would suggest a call to your local support or installer. It will be helpful if you are in front of the dimmer rack to test solutions.
    Luke
  • I've done this step , but the griven 575,1200 not listed.
    And whin in try to patch it manually i did not find the gobo rotation, gobo wheel rotation, frost prism.
    what to do now?????
  • If a fixture is not in the fixture list, make sure you have the most current software- 1.9.12.  ETC is constantly adding more fixtures to the library.  If it's still not there, you can either create one manually.  Not really recommended, but there is a section in the manual on how to do it.  The recommened procedure is to contact ETC tech support and ask for the fixture to be created.  You may need to send them the DMX control information.
