Multiple cue lists and macros
What is the opposite of an Assert and how does one go about recording it into a macro?
The sound guy is triggering a variety of flashes via MSC by firing a set of macros to simulate flashes of explosions using various lighting instruments that are also being controlled by the master cue list. I want him to be able to grab control, execute a secondary cue list, then release control back to the master cue list, with those lights returning to the state they are supposed to be at in the master cue list.
According to the training videos and documents this is supposed to be possible by running the secondary cue list on a fader and then using {Off} to release the levels back to the master play list. I can't make this work and I don't know what I am doing wrong. Does anybody have a sample macro I could use as a template?
  • Following up with things I have learned in case it might prove useful to others, or aid ETC Support in confirming this is expected behaviour.
    Hans helped me reframe the question and I was able to get this to work, mostly, by using "Assert 0" to force control back to the master cue list, which is running on the master fader. I say "mostly", because there seems to be inconsistent behaviour when this is done via macro. Foreground macros don't work with the syntax I am using, and background macros don't always execute the Go To Cue, or perhaps they do, but not necessarily on the the asserted cue list, which might be timing related. Where the Go To Cue is particularly an issue is when an ML is part of the cue. It is not coming back to the main cue list unless the the Go To Cue command is entered manually. Is that a User 0 versus User 1 issue?
    2012 10 30 10:08:08 Context Cue 91 4
    <snip>
    2012 10 30 10:08:32 Eos Consol Firing Macro 88
    2012 10 30 10:08:32 Key_Event U:0: Live CLEAR_CMDLINE
    2012 10 30 10:08:32 Key_Event U:0: CLEAR_CMDLINE
    2012 10 30 10:08:32 Context (L)USER: 0-> Live
    2012 10 30 10:08:32 Context Cue 1 2
    time: 330 10:08:32 Context Go 33
    time: 030 10:08:33 Context Off 33
    2012 10 30 10:08:34 Key_Event U:0: Assert 0
    So then I tried using the fader Off command which might produce better results, but I won't know until I try it with the live rig.
    2012 10 30 10:08:40 Key_Event U:1: MacroButton
    2012 10 30 10:08:41 Key_Event U:1: 3
    2012 10 30 10:08:41 Eos Consol Firing Macro 33
    2012 10 30 10:08:41 Key_Event U:0: Live CLEAR_CMDLINE
    2012 10 30 10:08:41 Key_Event U:0: CLEAR_CMDLINE
    2012 10 30 10:08:41 Context (L)USER: 0-> Live
    2012 10 30 10:08:41 Context Cue 1 3
    time: 330 10:08:41 Context Go 33
    2012 10 30 10:08:42 Key_Event U:0: Assert 0 Go_To_Cue Time 0
  • ... and yet more feedback on my ongoing struggles with what ought to be really simple but isn't (see the first post for the scenario)
    Macro (background mode) is:
    Go 32 Macro_Wait 1 Assert 0 Macro_Wait Go_To_Cue Time 0 *
    which is supposed to execute cuelist 32 (looping 2 step cue), wait for it to finish, assert the main cue list and then force that cue to bring back any channels that might have been grabbed by 32.
    The Go_To_Cue doesn't consistently work when fired from a macro but always work when executed manually. So the macro has been modified to mostly run in the background but fire the Go_To_Cue in the foreground by calling another macro for that task:
    Go 32 Macro_Wait 1 Assert 0 Macro_Button 40 *
    Macro 40 (foreground) contains:
    Go_To_Cue Time 0 *
    This convoluted approach seems to be yielding more consistent results but I won't know until the run-through tonight. Maybe the Assert should be a Fader_Assert and also run in the foreground, but I don't have time to experiment.
    I think things would be a whole lot simpler if there was a Macro mode called do-what-it-would-have-done-if-somebody-physically-pushed-the-button.
    And I always thought, that is what the learn button does. Or is it not.....
    Have you tried using learn?
    [edited by: FloBaeumler at 8:25 AM (GMT -6) on Thu, Nov 1 2012]
  • Florian is correct.  You should be able to write a macro for your secondary cue list of [Release] + [Load].
    a
  • As this long chain will attest, I agree that I should be able to write a macro, but the macros do not behave as expected. I have spent about 10 hours getting to this point and shown all my work but it doesn't work as expected, and I get different behaviours when it is a foreground or background macro. So the question remains, what should I be doing.
    Thanks.
    /Karl
    ... and yes I started with "Learn" and it did not work without having to add Go To Cues and even then it didn't work because the Go To Cue wouldn't take in a background macro.
    [edited by: sk8rs_dad at 12:58 PM (GMT -6) on Thu, Nov 1 2012]
  • OK.  One step at a time.
    Just to be clear.  You are simply trying to write a macro that releases a secondary cue list to the last cue list that had control of specific lights - which in your case is your master list?  I'm not clear on why you were asked to use an assert command or go to cue - one of the developers and I discussed this and unless we are completely missing something, we are confused by that.  But I've put in a call to Hans.  Perhaps he can help clarify.
    Please assure that you have not set a background disable flag on your master cue list.
    Put yourself into some cue in the master list that involves these lights.
    Manually playback your secondary list.
    Can you use the release command on your secondary list manually and return control to the master?   (That would be Release and Load).  The release command will leave the secondary cue list where it is.  If you want to release and also set the secondary list to the top of the que, use Off and Load.
    If you can do it manually, can you learn a macro
    learn macro n enter [Off or Release] and Load. Learn
    Rerun the cues as before and manually run the macro?  Does it work?
    If that works, how are you triggering the macro in your show.
    I just tried this, and unless I'm missing something that you are trying to do, it works fine.
    If it isn't working, please email me your showfile (anne.valentino@etcconnect.com)
    Thanks so much.  We will sort out what is going on.
    a
    [edited by: Anne Valentino at 2:30 PM (GMT -6) on Thu, Nov 1 2012]
  • Thanks Anne. I have always figured it is something I am screwing up but I had to blaze ahead with limited knowledge because we open on Sunday and a half-baked answer is better than no answer at all. I will give your recommendation a shot when I am back in the theatre this evening. I thought I had already tried it but maybe I messed up a keystroke somewhere.
  • No problem at all.   Very interested to hear what you find.
    Thanks much!
    a
  •  release and load brings back the intensity in the primary cue list  but the color parameter and possibly other np parameters are not restored  to where they were in the primary cue list.  they track in from an ealier cue.  i will send the showfile after rehearsal since i don't have internet access
    [edited by: sk8rs_dad at 4:49 PM (GMT -6) on Thu, Nov 1 2012]
  • Ok.  Will need to know the cue on the primary you are restoring to and the cue on the secondary you are restoring from - and the channels.
    Thanks much!
    a
  • I think I have figured out what is happening, and I think its a bug.
    Try this scenario:
    • Create a default preset and set the color temperature of some D40s to 5000.
    • Create a master cue list that has color temperature as null throughout.
    • Create a second cue list that sets color temperature to 2000 -- don't ask me why or how... it's been a long week :)
    • When the secondary cue list fader releases to the main fader the color temperature does not come back to the default.
    I didn't get a chance to confirm my suspicion before I had to leave the theatre to run an errand but based on what I was seeing it would explain the red-shifted splotches on certain areas of the cyc that had been part of the secondary cue list.
    Plausible?
  • Nope.... not a bug.  If you have nulled the parameter in the master, when you release to the master, the color temp is not getting a new instruction - so it stays where it is (nothing moves unless you tell it to move).  If you want it to home when you return to the master, you need to have the home values stored into (either as moves or tracks) your master list.   The general rule for NPs is that we don't move them unless you give us an instruction to move them.
    Hope that helps.
    a
  • I think we're going to have to agree to disagree on that.
    If the NP value in the master cue list is coming from the default Preset prior to executing something on another fader, it should return to the default Preset upon releasing that fader. That is, the default Preset should act as though it tracked in from Cue 0. Otherwise, Release, Off, and Assert 0 won't actually do what they allege to do which is return the rig to whatever look was active before the event that changed it. Is the workaround to record the default preset into the first cue in every list and force it to track through?
  • You need to have an instruction for those lights in the master cue list if you want them to return to it.   So you can go to the first cue in the master list and add the necessary parameters at their home value.
    Thanks much!
    a
    The entire principle of a move fade / tracking console is that nothing will ever move unless it is given a move instruction. Those default presets are not background levels unless they are specifically reference in a cue or sub etc. They are null values (gray).
    I wouldn't call this a work around, it's actually how this should function, but yes it will give your main list a background level to be restored to.
    Cheers
    Dan
    [edited by: dsmurfin at 11:28 AM (GMT -6) on Fri, Nov 2 2012]
