Scroller Calibration Values vs. Manually Entered DMX
I have a strange problem with a few scrollers on my rig...
I've calibrated a few, but the changes to the calibration table seem to be ignored when the corresponding frames are called up. However, if I set the color frame to the updated calibration value manually using "@//", the scroll moves to the correct position...
I assume that the scroller calibration values would simply override scroller values sourced from the patch... is this not always the case? The misbehaving scrollers in question are 7" Forerunners, if that makes any difference, and curiously, none of the other types of scrollers we use seem to have this problem.
Cheers all.
