Gio cuestack master? Using gio for live music
Hi I am using a gio to busk lights to music and I'm having a few problems setting up the desk how I would like to operate. I have made a cue stack of cues which is currently assigned to the master faders. I'm using pre programmed times but I would like to be able to fade up and down the entire cue stack like you can on a GrandMA 2. This would allow me to mix looks created using subs and the direct selects if I could just have the equivalent of a grandmaster for the cue stack which would allow me to take the cue stack out entirely but still enable me to control the lights in the cue stack separately whilst the master is down and also go between different cues I.e go to cue 5 or just hit go whilst the master is down and then bring up the master and fade the cue up manually.
I don't need to be able to manually cross fade between cues.
If possible I want to leave the cue stack on the master fader rather than move it to another sub fader.
Is this possible?
Also why is there no easy way to go back a page? The only way I have found is to use the wheel whilst holding down the fader page button. It needs to be on the touch screen or shift fader page.
