On the facebook group, ETC Eos Programmers someone asked if there was an easy way to renumber a cue list that has lots of points, and after a lot of research it seems the short answer is no.
If you have the following cue list:
Q1
Q1.1
Q2
Q2.5
... currently if you copy it to another cue list, it will copy with all of the points attached.
Here's my suggestion. An "interval command" after the Copy_To or Move_To command.
So if I typed in Cue 1 thru 2.5 Move_To 3 + 1, my cue list would then look like:
Q3
Q4
Q5
Q6
...or if I typed in Cue 1 thru 2.5 Move_To 3 + .5, my cue list would look like:
Q3
Q3.5
Q4
Q4.5
This way renumbering cues, be it just a small sequence or an entire show, can be done in a few keystrokes instead of manually with each cue.
