I have a question about the Gobo/Colorwheel handling of High End Systems Cyberlights (CL or SV) on Gio (or any Eos range console in fact). I should add that I see the lights only on ESP Vision right now since I don't have the "real" ones yet.
When I select rotatable gobo 1 or 2, everything is like normal. When I select one of the higher numbered ones, I can't really get them out anymore. After I select "Open" or sneak the parameter, I can watch the gobowheel move to open very very slowly (in like 40 seconds). This is without any cue being active or any background value other than default home.
The fixed color wheel can't get to Open anymore after having one of the colors in except for "Open 2" at the end of the range...Even commands like "Color Home" or sneaking the parameter don't release the colors.
Has anyone seen this behavior on Cyberlights before when using an Eos range console ? I admit this is more a Cyberlight question than a console question ;) I personally see it as either a Vision or a fixture profile issue.
- Matze
