Select Active, Enter, then dial on the wheel.
On the Ion, the Select key populates the softkeys with the options, one of which is Active.
SB
Steve Bailey said:Select Active, Enter, then dial on the wheel.
You can also set the playback faders to control the level of that cuelist. Double hit [Cue} to open the cue list index and change the {Fader} for your list to I Master.
Nick
Nick Simmons said:You can also set the playback faders to control the level of that cuelist. Double hit [Cue} to open the cue list index and change the {Fader} for your list to I Master.
Nick
Thanks Nick, that's one I always forget.
SB
