Preset Usage?
Hopefully someone will come along with a simple answer or a fun query trick, but I'm at a loss.
When trying to check the usage of a single preset, none of the methods for checking that I can think of work as expected or as desired.
  • [About][Preset] X is good, unless the preset I'm checking usage on only occurs as a live move. For example, if (191) is in Preset 111 during cue 1 and in cue 2 it moves to preset 112 without changing intensity AND this is the only usage of Preset 112, [About] shows Preset 112 as unused.
  • [Blind][Cue] 1 [thru] Last cue [Enter][Query][is in][Preset] X throws an error. Maybe something in my syntax is off here?
  • Checking the pdf utilization report does work, but is very clucky as a mid-tech check.
It seems like there must be some simple way to do this, so I hope I'm just missing it?
