Snapshot records submaster set up (faders) also records the master cue stack. Any possible way NOT to record the master fader stack in a snapshot and still record the set up of the fader wing?
thanks
Molly
thanks
Molly
If you release the cuelist from the master playback before you record the snapshot (Shift&Load) then re-load it later your snapshot will not affect this playback.
Be aware though that any other cuelists currently loaded on your fader wing would have their pending cue recorded into the snapshot.
Graham
FYI - if you just want to change the fader page, and not snapshot the loading/levels/pending cues, a macro may be a better option.
[Learn][8][FaderPage}&[3][Learn], for example.
