Hi
I would like to change which universes of DMX that are outputed through the two DMX output of my GIO. How is this done?
Best regards
Kjems
Hi
Best regards
Kjems
Hi Kjems,
1. Exit Gio Application
2. Setup in Shell
3. Local I/O Settings.
4. Here you can change the universes for local dmx ports.
5. Have fun!
Hi Corey
Thanks for the very fast reply.
Best regards
Kjems
How do I change both dmx ports to the same univers on gadget 2 from etc using my computer eos board
In Setup > Device > Local Output you'll see four lines for Console ports.
Below it you should see a section for your two Gadget ports, identified by the serial number of your gadget.
In the Address column you can enter the first address to be output by this port. If two ports have the same start address you have both ports using the same universe.
