Hi
How do I remove a value from a cue. I dont want to set it to zero I want to "release" it from the cue?
Anders Kjems
Hi
Anders Kjems
Hi Corey
ch 1 @ <Enter> is giving ch 1 the value of zero and not removing it from the cue. Which means that when I run the cue ch 1 is at "0" (in the same blue color as the rest of the channels that are on in that cue. And if I run the cue when ch 1 is on it goes to zero.
Anders
Assuming you are making the change in Live mode, remember to update the cue.
When you pres 1 @ Enter. Ch 1 goes to zero (red text) and if I I store or update the cue the channel have 0 as value. Its still in the cue. Is @ enter not only a way to turn a ch to zero and not a way to remove it?
with @ Enter you make the channel "transparent" (i.e. tracking), shown in magenta (as soon as you recorded). if you have a a channel that has 0% in the cue before and then you @ Enter, you get a red 0. then you update it and the red 0 converts to a magenta - . that means a tracking 0. and that's what you want.
If you want to remove a channel from a cue list (for example, it is used in cues 1>10 but not in 11 onwards) you can use {Make Null} in Blind.
Have a play with that and see if that is what you want?
Luke
It works fine if you are not editing the first cue in a list. I don´t know where it gets the zero value from but a zero value is stored when you use @ enter update in the first cue.
i can't confirm that... are you doing this in blind (cue edit), in blind tracksheet or in live?
ah, now i see it. you are doing this in live, right? if you go to blind it works like you expected.
ueli
Thank you. That was the trick!
Anders Kjems
