Does anybody know how to transfer and already made effect into a submaster on a ION? What I'm trying to do is turn on an effect at the push of button on the fader controls
From live or blind. Type "Sub # , press Softkey 1 (which should be "mode") until it reads "effect sub". Hit Enter.
Depending on your effect type,
Absolute Effect: type "effect at enter" and record sub
Other Effects: Channel numbers then "effect" at Enter. and record sub.
In both cases, the bump button becomes the "Run" button.
when you only won't to start the effect with push the button... it´s very easy.
click double SUB > SUB X Enter > Edit (Softkey)
Channel x thru x effect x enter
Go back to LIVE and push the button...
The effect must run.
Be sure, your channels are not selected or manual.
Your SUB-Mode ist additive. You can change the IN-Hold-Out Time for the sub.
For change the time >>> double SUB > SUB x Enter. Time Time Time (IN Hold OUT)
For the HoldTime can be interested HOLD and MAN (manuall for the time your push the button)
The "second" level (-: is play with the SubMode > EffectSub
Here you can give the Fader a function. Change the Rate, Skale...
You must say it in the Effect X. (by entry & exit).
Push the button on the Fader to start and stop the Effect and move the Fader.
Hope that helps.
Have fun (-:
