2.0 bug, facepanel shortcut error
Hi Everyone:
2 things to be aware of:
1) on the Facepanel Shortcuts sheets, it shows that [Shift] + [Up] [Shift] + [Down] [Shift]+[Left] [Shift]+[Right] can be used to move and re-size columns.
These commands are for PATCH only (or so ETC Techincal Help line tells me). AND it isn't implimented yet.  (Yet it's been in the release notes prior to v2.0)
These should be marked as the Page [Arrow up] etc, top right of the Ion Console. (although I never did try the arrow keys on the external QWERTY keyboard . . .)
[2)  The bug:   [Shift] + [Mouse Button Left] or [Mouse button Right]:  This will hide or remove a column from the Cue list screen.  (Great, I love this.  Keep it.  Not a bug (see below)).
[shift] + [Select] WILL reset the playback display columns.
I have 2 monitors, with the single Cue list running on both, in a really long view.  (Cue List is expanded onto the left screen)  My right hand screen shows the lock in the top left of the screen, and there is no lock on the Left screen.
I can't get the gold box (by tabbing) over to the second (expanded) screen where the CIA appears.
When I hid a few columns in that screen, I couldn't get them back again, either by using [Shift]+[Select], or trigging the snapshot.  Hidden columns on the right Screen (with the lock, tabbed gold box around it) will re-appear with [Shift] + [Select].
A deep clear will restore all the columns in this case.
Tech Services is aware.  I thought I would mention it here.
Andrew Riter
Chan Centre for the Performing Arts
  • Here is a little more information.
    The ability to move columns, [Shift + Page Left/Right] broke towards of the end of the 2.0 development, sorry.   It allowed you to move the columns around in Patch Database display specifically.  [Shift + Up/Down] allows you to re-size columns and still works in Blind Spreadsheet.  These are part of the In-cell editing feature that is only partially implemented.  As Anne says, it's on the list.
