Hello.
I have a cue with an effect recorded into it. And I'd like to run this cue manually. The problem is when I move faders in the lower position and hit the 'go' button to start the manual crossfade, effect starts just after I've pressed the 'go' button, and I can't control its intensity with the crossfader. The type of effect is absolute, and it uses intensity palettes as actions. So, effect contains only intensity parametrs. I've tried to set the cue time to manual and use the crossfader in manual master mode, but it does not help me.
