Ion Monitor VGA & DVI combination
Howdy,
I have the Ion running v.2.0. I have 1 DVI Touchscreen and 1 VGA Monitor. I recently changed the primary monitor to be the VGA (so I could get the CIA on the VGA one) using the old powering up with one connected etcetera trick. However, since doing this the DVI touchscreen is not being recognised as a touchscreen and therefore I cannot configure it - rendering it unusable. I can swap it back easy enough and it'll recognise it again but I want to use the full touchscreen monitor for my direct selects (hence moving the CIA).
If you have any suggestions they'd be greatly appreciated.
  • If you rearrange the monitors you'll always need to recalibrate the touchscreen, as the console has no way of knowing which video goes with which touch.
    During calibration the first step is identifying which physical monitor the touchscreen is actually part of.
    You'll need to press a key on external keyboard to skip on to the next physical monitor - I think it's Enter, but it says on the calibration screen.
