EOS button modules & 2.0
We have button modules installed on our EOS primary and secondary displays.   After installing 2.0 the far right side of each display - the column that says "20/50'" "Select," "Expand" etc. - has shifted to the left about 1/4". Therefore,  part of the info. is under and to the left side of the vertical divider on the button module.
When we adjust the Horizontal Offset it only moves the left 2/3rds. of each display.  We can't get the column on the right side of each display to move at all.
Suggestions?
