Effect Grouping Offset
Is it possible to adjust the offset of the grouping function in an effect?  Currently you click spread (?) or whatever and it evenly cascades the effect across the range of fixtures you selected.  Can you however adjust how the effect offsets from one fixture to the next, so that it isn't evenly spread across the range but can be moved tighter together for example.
